[mapserver-users] No errors, but no lines on output map.
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 5 21:53:24 EST 2002
>>INFO: Open of `web/mapserv_demo/test/data/carroll'
>>using driver `TIGER' successful.
>>1: CompleteChain (Line String)
>>2: AltName (None)
>>3: FeatureIds (None)
>>4: ZipCodes (None)
>>5: Landmarks (Point)
>>6: AreaLandmarks (None)
>>7: KeyFeatures (None)
>>8: Polygon (None)
>>9: EntityNames (Point)
>>10: IDHistory (None)
>>11: PolyChainLink (None)
>>12: PIP (Point)
>>13: TLIDRange (None)
>>14: ZipPlus4 (None)
>>Note:
>>When I speak of layers below, I'm talking about the argument to
>>CONNECTION in a LAYER definition. E.g.,
>>CONNECTON "data/carroll, 0"
>>I have skimmed the Tiger/LINE 2000 spec (from the Census Bureau) and
>>have some understanding (perhaps wrong :) of how the different record
>>types relate. Based on that, I thought that I should get a map of the
>>roads from layer 1 (CompleteChain). However, the only way I get any
>>output at all is if I use 0. If I change the layer arg to 5 and the
>>LAYER TYPE to POINT, I get nothing and the result is returned very
>>quickly unlike what happens when I use 0 which takes quite a few
>>seconds.
It is a peculiarity of the OGR integration in MapServer vs. ogrinfo that
the layer number is different. Ogrinfo is reporting 1 based numbers while
MapServer requires zero based indexes. so CompleteChain is layer index 0.
This is noted in the OGR-HOWTO but is somewhat unobvious.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
