[mapserver-users] No errors, but no lines on output map.
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 5 20:29:46 EST 2002
Ben,
Do you want shape files for Carroll Co.? It would probably work better
than OGR. What is the tiger file name you are working with for Carrol
county?
Can you handle a big email or would you rather download it froma
website? Assume you want it :)
-Steve W.
Ben Logan wrote:
> On Fri, Apr 05, 2002 at 02:41:23PM -0500, Stephen Woodbridge wrote:
> > Ben,
> > Change your map file to :
> > UNITS DD
> > # extents for all of Virginia
> > EXTENT -83.682000 36.543600 -74.952000 39.769180
> > should fix your problem.
> Thanks, that did at least cause something to show up. However, I
> wanted to change the layer to represent landmark features, and now
> nothing will show up again (same EXTENT as you gave above). The
> output of ogrinfo on the Tiger data looks like this:
> INFO: Open of `web/mapserv_demo/test/data/carroll'
> using driver `TIGER' successful.
> 1: CompleteChain (Line String)
> 2: AltName (None)
> 3: FeatureIds (None)
> 4: ZipCodes (None)
> 5: Landmarks (Point)
> 6: AreaLandmarks (None)
> 7: KeyFeatures (None)
> 8: Polygon (None)
> 9: EntityNames (Point)
> 10: IDHistory (None)
> 11: PolyChainLink (None)
> 12: PIP (Point)
> 13: TLIDRange (None)
> 14: ZipPlus4 (None)
> Note:
> When I speak of layers below, I'm talking about the argument to
> CONNECTION in a LAYER definition. E.g.,
> CONNECTON "data/carroll, 0"
> I have skimmed the Tiger/LINE 2000 spec (from the Census Bureau) and
> have some understanding (perhaps wrong :) of how the different record
> types relate. Based on that, I thought that I should get a map of the
> roads from layer 1 (CompleteChain). However, the only way I get any
> output at all is if I use 0. If I change the layer arg to 5 and the
> LAYER TYPE to POINT, I get nothing and the result is returned very
> quickly unlike what happens when I use 0 which takes quite a few
> seconds.
> I know that it would take a comination of layers to get the names of
> the landmark features (or road names, etc), but it seems like I should
> get a plot of the points.
> Thanks,
> Ben
> Ben Logan: ben at wblogan dot net
> OpenPGP Key KeyID: A1ADD1F0
> Any stone in your boot always migrates against the pressure gradient to
> exactly the point of most pressure.
> -- Milt Barber
