[mapserver-users] displaying query problem
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Sun Apr 7 15:51:08 PDT 2002
I am trying to display query results, I am using code from the gmap demo.
In short I do this, the gmapDumQueryResults() is unchanged from gmap demo.
In my map file I have:
METADATA
"DESCRIPTION" "Buildings"
"RESULT_FIELDS" "Area Perimeter"
END
Area and perimeter are the attribs I want displayed.
When I query a point in my map I get:
Nothing found at query location. even though I click on a layer.
This happens because the numResults val. in gmapDumpQueryResults() is
zero:
$numResults = $oLayer->getNumResults();
if ($numResults == 0)
continue; // No results in this layer
php code:
if ( isset($HTTP_POST_VARS["mode"]) ) {
$nClickPixX = intval($HTTP_FORM_VARS[mapa_x]);
$nClickPixY = intval($HTTP_FORM_VARS[mapa_y]);
$dfWidthPix = 600;
$dfHeightPix = 500;
$dfMinX = $map->extent->minx;
$dfMaxX = $map->extent->maxx;
$dfMinY = $map->extent->miny;
$dfMaxY = $map->extent->maxy;
if( $HTTP_POST_VARS["mode"] == "query") {
$nClickGeoX = GMapPix2Geo($nClickPixX, 0, $dfWidthPix, $dfMinX,
$dfMaxX, 0);
$nClickGeoY = GMapPix2Geo($nClickPixY, 0, $dfHeightPix, $dfMinY,
$dfMaxY, 1);
$oClickGeo = ms_newPointObj();
$oClickGeo->setXY($nClickGeoX, $nClickGeoY);
// Use '@' to avoid warning if query found nothing
@$map->queryByPoint($oClickGeo, MS_SINGLE, -1);
gmapDumpQueryResults();
} // end of if loop
Do I need to call some other functions.
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
More information about the MapServer-users
