[mapserver-users] CGI Map changes
Frank Koormann
frank.koormann at intevation.de
Mon Apr 8 11:26:42 EDT 2002
Robert,
* Robert Crossley (robert at wotzhere.com) [020408 13:24]:
> Hi all,
> One reference said that MapServer is stateless, so does this mean that
> once it renders and image it forgets what it has done for that user,
> and thus I would assume that it needs to have all parameters that are
> different to the Map file defined on each call?
> It would be easy enough for me to test this for one user, but what
> about with multiple sessions where each user has a different data
> value would require a bit more effort.
Well, only the mechanism has to be proven. Once tested it can be used
for multiple users: Template substitutions can be used to exchange
parameters between cgi-binary and web browser. Something like
layer1_data=someshape in the CGI parameter string will be picked up by
the mapserver whic in trun will replace any occurence of [layer1_data]
in a template by "someshape".
On the other hand you may have a look at the SAVEMAP feature
(http://mapserver.gis.umn.edu/doc/cgi-reference.html)
Therewith you can store a new mapfile (for a session) and only have to
ping-pong the mapfile name between server and browser.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
