[mapserver-users] php-dbase replace error
Jeff McKenna
mckenna at dmsolutions.ca
Mon Apr 8 15:47:39 EDT 2002
Hello,
There is a known bug in the php4.0.6 dbase_replace_record function. It
has been fixed in php4.1.2, and you can get a phpmapscript dll for that
version on our site at:
http://www2.dmsolutions.on.ca/mapserver/dl/php4.1.2_php_mapscript_36-dev_libwww.zip
Jeff
Shaik Anwar Hussain wrote:
> Hello List,
> I am trying to replace the dbase records using php_mapscript.
> Here is my php code. Its rewriting the records with null values. i want to
> replace with different values. does any one can help me whats wrong in my
> code.
> Where photo is my shapefile name, it has 4 fields. i am using php4.06,
> mapserver3.5, apache,windows 2000.
> <?php
> dl('php_mapscript.dll');
> dl("php_dbase.dll");
> dl("php_proj.dll");
> function delete_photo($shpfname, $pamcode)
> $shapef = ms_newShapefileObj($shpfname,-2);
> $dbfile = dbase_open($shpfname, 2);
> $numrec = dbase_numrecords($dbfile);
> $nf = dbase_numfields($dbfile);
> echo $numrec," ",$nf,$pamcode,"<BR>";
> $pamscode = "1";
> for($k=0; $k<$numrec; $k++)
> $rec = dbase_get_record($dbfile,$k);
> //echo $rec[0],$rec[1],$rec[2],$rec[3],"<BR>";
> if (strtoupper(trim($rec[2])) == strtoupper($pamcode) )
> $f1 = $rec[0];
> $f2 = $rec[1];
> $f3 = $rec[3];
> //echo $f1,$f2,"<br>",$rec[0].$rec[1].$rec[2]."<br>";
> dbase_replace_record($dbfile,
> array($f1,$f2,$pamscode,$f3),$k);
> $shapef->free();
> dbase_close($dbfile);
> } // End of the function photo delete
> # Begining of main program
> $shpfname1 = "E:/Program Files/Apache
> Group/Apache/htdocs/php406/data/photo";
> $num='170A';
> delete_photo($shpfname1,$num);
> exit;
> Thanks,
> Anwar
> www.atsincorp.com
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
http://www.dmsolutions.ca/
