It is known error in the php-dbase modul. You have two possibilities:
1. patch the current dbase.c code according to attached document and
recompile php.
2. use newer version of PHP where this error has been already fixed (PHP >=
4.1.)
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Shaik Anwar
> Hussain
> Odesláno: 8. dubna 2002 21:03
> Komu: Mapserver-Users (E-mail)
> Kopie: Ben Lewis
> Pøedmìt: [mapserver-users] php-dbase replace error
> Hello List,
> I am trying to replace the dbase records using php_mapscript.
> Here is my php code. Its rewriting the records with null values. i want to
> replace with different values. does any one can help me whats wrong in my
> code.
> Where photo is my shapefile name, it has 4 fields. i am using php4.06,
> mapserver3.5, apache,windows 2000.
> <?php
> dl('php_mapscript.dll');
> dl("php_dbase.dll");
> dl("php_proj.dll");
> function delete_photo($shpfname, $pamcode)
> $shapef = ms_newShapefileObj($shpfname,-2);
> $dbfile = dbase_open($shpfname, 2);
> $numrec = dbase_numrecords($dbfile);
> $nf = dbase_numfields($dbfile);
> echo $numrec," ",$nf,$pamcode,"<BR>";
> $pamscode = "1";
> for($k=0; $k<$numrec; $k++)
> $rec = dbase_get_record($dbfile,$k);
> //echo $rec[0],$rec[1],$rec[2],$rec[3],"<BR>";
> if (strtoupper(trim($rec[2])) == strtoupper($pamcode) )
> $f1 = $rec[0];
> $f2 = $rec[1];
> $f3 = $rec[3];
> //echo $f1,$f2,"<br>",$rec[0].$rec[1].$rec[2]."<br>";
> dbase_replace_record($dbfile,
> array($f1,$f2,$pamscode,$f3),$k);
> $shapef->free();
> dbase_close($dbfile);
> } // End of the function photo delete
> # Begining of main program
> $shpfname1 = "E:/Program Files/Apache
> Group/Apache/htdocs/php406/data/photo";
> $num='170A';
> delete_photo($shpfname1,$num);
> exit;
> Thanks,
> Anwar
> www.atsincorp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020409/8c28f06f/attachment.htm>
