[mapserver-users] Mapserver and Windows
Lowell.Filak
lfilak at medinaco.org
Tue Apr 9 11:35:07 EDT 2002
Our experience has been that:
1) Linux is cheaper if not altogether free.
2) Apache, Perl, libtiff, gd, PHP is usually installed as part of the
system and if it isn't it seems to install easier than on other platforms.
3) A lot of the system commands built into *n*x are not as readily
available on other platforms, ie. find & cron. Which may not seem like
much to start with but sure helps when deleting those pesky temporary files.
I would suspect there is a work-a-round or "add-on" that can be purchased
to fix some of the above situations, however the more I work with it the
more I realize how much is built-into the system that I take for granted.
My $0.02
Lowell F.
On Tue, 9 Apr 2002, Stefano Bonnin wrote:
> Hi,
> I have a simple question: which advantages I have if I use mapserver in a
> unix environment instead in a windows enviroment?
> In other words, are there more disadvantage if I use a windows environment
> (instead unix)?
> Thanks
> Outgoing mail is certified Virus Free. (FLASHH!)
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.343 / Virus Database: 190 - Release Date: 22/03/02
