[mapserver-users] proj problem?
Giorgio Volpe
giorgio at nauta.it
Thu Apr 11 05:28:50 EDT 2002
I used mapserver & mapscript without proj support and it was perfect!
Now i'm tring to add proj: I installed debian proj package (v 4.4.5)
and compiled mapserver with:
./configure --with-postgis=/usr/lib/postgresql/bin/pg_config
--with-tiff --with-jpeg --with-freetype --with-png
--with-gd=static,/home/giorgio/work/map/gd-1.8.4/ --with-proj
everything seems ok but ... when I try to see itasca demo in the
browser, i can see the first map but if i try to zoom or pan then the
script dies with no output at all.
No trace in apache error log, (only a "Premature end of script headers")
I also log error (with SetEnv MS_ERRORFILE /var/tmp/map_error.log) but
there is no output there!
What can i do to find out the problem?
This is my mapserv -v
MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
thank in advance ...
Giorgio
