[mapserver-users] proj problem?
Lowell Filak
lfilak at medinaco.org
Thu Apr 11 10:33:09 EDT 2002
Take a look at the html source in the browser (View->Page Source) the "Premature" statement is actually returned from the client itself.
Lowell F
The following message was sent by Giorgio Volpe <giorgio at nauta.it> on Thu, 11 Apr 2002 11:28:50 +0200.
> I used mapserver & mapscript without proj support and it was perfect!
> Now i'm tring to add proj: I installed debian proj package (v 4.4.5)
> and compiled mapserver with:
> ./configure --with-postgis=/usr/lib/postgresql/bin/pg_config
> --with-tiff --with-jpeg --with-freetype --with-png
> --with-gd=static,/home/giorgio/work/map/gd-1.8.4/ --with-proj
> everything seems ok but ... when I try to see itasca demo in the
> browser, i can see the first map but if i try to zoom or pan then the
> script dies with no output at all.
> No trace in apache error log, (only a "Premature end of script headers")
> I also log error (with SetEnv MS_ERRORFILE /var/tmp/map_error.log) but
> there is no output there!
> What can i do to find out the problem?
> This is my mapserv -v
> MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
> INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> thank in advance ...
> Giorgio
