[mapserver-users] PHP Mapscript 3.4 to 3.5 - shptree layers no
longer work
Daniel Morissette
morissette at dmsolutions.ca
Fri Apr 12 14:34:29 EDT 2002
David Kriske wrote:
> I recently have been in the process of upgrading my PHP Mapscriptapplication
> from version 3.4 under PHP 4.0.4p1 to version 3.5 under PHP 4.0.6, using the
> precompiled dlldated 10.15.2001. Using this version, layers indexed using
> SHPTREE no longer display; theapp hangs indefinitely. Renaming all the .qix
> files allows the layer to work. I saw mention of a bug that was fixed involving
> PHP Mapscript3.5 and shapetree. How can I get around this problem?
David,
This bug was fixed after the 3.5 release, around the end of January, so
you need a DLL built after that date. The following one should do:
http://www2.dmsolutions.ca/mapserver/dl/php4.1.2_php_mapscript_36-dev_libwww.zip
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
