[mapserver-users] Can the map be stretched vertically?
Ma
marin at here.is
Tue Apr 16 06:17:04 EDT 2002
and do you use the same map projection in MapInfo?
Ma
Bjarni Pjetursson wrote:
> I've taken a tab-file from MapInfo, saved it as a shp-file, and put it into
> MapServer.
> In MapInfo the map is square but when displaying the same map in MapServer
> the map is rectangle. The height of the map has halfed. Why is that?
> It seems that different companies have different idears as to how to display
> GIS data. I tried Geographic Explorer from Blue Marble Software (freeware),
> and it showed the map like MapServer do. Actually, I can only get MapInfo to
> show the map square.
> My customer has gotten used to the way MapInfo shows the map. Can I make
> MapServer show the map the same way?
> You can see the two different maps here:
> http://www.dynameks.com/cwu-btp/mapserv
> Image 1 is from MapInfo and Image 2 is from MapServer.
> Regards
> Bjarni Thor Pjetursson
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
