[mapserver-users] Problem with SIZEUNITS
Anders Knudstrup Hansen LE34
akh at le34.dk
Wed Apr 17 07:06:08 EDT 2002
The problem was that I was using sizeunits on the class object....
The layer in the mapfile should've looked like this:
layer
NAME "Search_areas"
TYPE Point
STATUS on
connectiontype ogr
connection "data/tab/Radier.TAB"
classitem "Op"
SIZEUNITS meters
class
EXPRESSION "80"
SYMBOL "circle"
SIZE 160
color 255 0 0
end
end
Thanks
-----Oprindelig meddelelse-----
Fra: Stepan Kafka [mailto:stepan.kafka at centrum.cz]
Sendt: 17. april 2002 12:38
Til: Anders Knudstrup Hansen LE34; mapserver-users at lists.gis.umn.edu
Emne: RE: [mapserver-users] Problem with SIZEUNITS
What do you have on the line above this one? Maybe there is the error. :-)
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uzivatele Anders
> Odesláno: 17. dubna 2002 9:59
> Komu: mapserver-users at lists.gis.umn.edu
> Pøedmìt: [mapserver-users] Problem with SIZEUNITS
> When I try yo use the sizeunits identifier I get the following error msg.
> loadClass(): Unknown identifier. (SIZEUNITS):(73)
> This is the output from my mapserver:
> \cgi-bin>mapserv -v
> MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Shouldn't sizeunits be supported by the version i'm using?????
> Thanks.
