[mapserver-users] Problem with SIZEUNITS
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 17 10:16:06 EDT 2002
Anders,
Well, I learn something new every day. :) I had not noticed SIZEUNITS in
my work with mapserver and the way you are trying to use it is very
interesting. I'll have to try that also.
I don't see anything obviously wrong with your LAYER definition,
hopefully someone else can help you.
Best regards,
-Steve
Anders Knudstrup Hansen LE34 wrote:
> The problem was that I was using sizeunits on the class object....
> The layer in the mapfile should've looked like this:
> layer
> NAME "Search_areas"
> TYPE Point
> STATUS on
> connectiontype ogr
> connection "data/tab/Radier.TAB"
> classitem "Op"
> SIZEUNITS meters
> class
> EXPRESSION "80"
> SYMBOL "circle"
> SIZE 160
> color 255 0 0
> end
> end
> Thanks
> -----Oprindelig meddelelse-----
> Fra: Stepan Kafka [mailto:stepan.kafka at centrum.cz]
> Sendt: 17. april 2002 12:38
> Til: Anders Knudstrup Hansen LE34; mapserver-users at lists.gis.umn.edu
> Emne: RE: [mapserver-users] Problem with SIZEUNITS
> What do you have on the line above this one? Maybe there is the error. :-)
> Stepan Kafka
> > -----Pùvodní zpráva-----
> > Od: owner-mapserver-users at lists.gis.umn.edu
> > [mailto:owner-mapserver-users at lists.gis.umn.edu]za uzivatele Anders
> > Odesláno: 17. dubna 2002 9:59
> > Komu: mapserver-users at lists.gis.umn.edu
> > Pøedmìt: [mapserver-users] Problem with SIZEUNITS
> > When I try yo use the sizeunits identifier I get the following error msg.
> > loadClass(): Unknown identifier. (SIZEUNITS):(73)
> > This is the output from my mapserver:
> > \cgi-bin>mapserv -v
> > MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG SUPPORTS=TTF
> > INPUT=TIFF INPUT=EPPL7
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > Shouldn't sizeunits be supported by the version i'm using?????
> > Thanks.
