[mapserver-users] single CLASS object to label all polygons?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 17 21:02:58 EDT 2002
Dylan,
You need to use a separate LABEL in every CLASS. Here is why ...
I think CLASS works like a SWITCH or CASE in that as soon a one class
section is executed no more are looked at. So if you put your label at
the bottom only the polygons that are not colored are labeled and if you
put it at the top the they are all labeles but not colored. You will
have to put the label block in every class section if you want them
colored and labeled.
-Steve
Dylan Keon wrote:
> I have a polygon layer that I've classified using CLASSITEM and a set of
> CLASS objects. I also want to display labels for each polygon. Do I need
> to use a separate LABEL within each class object (I know this will work), or
> is it possible to apply a single class object to label all polygons (I'm
> having trouble getting this to work)? I can successfully use an expression
> to label all polygons from one class object, but if I put that class object
> before the rest of the class objects, it disables the color rendering of
> those polygons. If I put it at the end of the other class objects, the
> labels are hidden beneath the rendered colors.
> Thanks,
> Dylan
