[mapserver-users] single CLASS object to label all polygons?
    Dylan Keon
    keon at nacse.org
    Wed Apr 17 18:53:32 PDT 2002
OK, that makes sense.  Thanks for the reply.
--Dylan
Stephen Woodbridge wrote:
> You need to use a separate LABEL in every CLASS. Here is why ...
> I think CLASS works like a SWITCH or CASE in that as soon a one class
> section is executed no more are looked at. So if you put your label at
> the bottom only the polygons that are not colored are labeled and if you
> put it at the top the they are all labeles but not colored. You will
> have to put the label block in every class section if you want them
> colored and labeled.
> -Steve
> Dylan Keon wrote:
> > I have a polygon layer that I've classified using CLASSITEM and a set of
> > CLASS objects.  I also want to display labels for each polygon.  Do I
need
> > to use a separate LABEL within each class object (I know this will
work), or
> > is it possible to apply a single class object to label all polygons (I'm
> > having trouble getting this to work)?  I can successfully use an
expression
> > to label all polygons from one class object, but if I put that class
object
> > before the rest of the class objects, it disables the color rendering of
> > those polygons.  If I put it at the end of the other class objects, the
> > labels are hidden beneath the rendered colors.
More information about the MapServer-users
