[mapserver-users] PHP, OGR, DGN help...
Assefa Yewondwossen
assefa at dmsolutions.ca
Thu Apr 18 11:32:29 EDT 2002
Hi There,
We have used recently here DGN files through OGR support and It was working ok.
I think that the dll you got did not include the latest GDAL/OGR library (with
proper support of DGN). I could send you directly the latest php_mapscript.dll
compiled for php4.1.2 if you are able to updgrade your php.
I am also going to put a new version on our download site later today.
Best Regadrs,
"Hankley, Chip" wrote:
> I need help integrating a DGN file in a MapServer app using PHP MapScript.
> Configuration:
> Win2K, IIS
> PHP 4.06
> php_mapscript_35.dll (1/11/2002) from DMSolutions site (this is in the
> PHP4.06_ms5_final distribution folder)
> Problem:
> The DGN doesn't render...
> No errors are returned, I just get a blank map window. The OGR part seems to
> be working b/c if I change the source to shapefile, I can get a shapefile to
> render (I converted the DGN to a shapefile in ArcView, and put it in the
> same directory, if I toggle the CONNECTION lines in the mapfile below, the
> shapefile works, the DGN doesn't).
> As an aside, I can't seem to get the OGRINFO command to work... I downloaded
> the GDAL binary for WINNT (http://www.remotesensing.org/gdal/). This is
> somewhat confusing b/c the gdal documentation focuses on raster data. Is
> there an OGRINFO utility that is different than the OGRINFO that is in the
> GDAL distribution?
> TIA
> Chip Hankley
> MAPFILE -
> # Start of map file
> SIZE 400 400
> EXTENT 263269 169782 285819 210757
> UNITS FEET
> SHAPEPATH "C:\Inetpub\wwwroot\OGR"
> IMAGECOLOR 204 204 255
> # Start of web interface definition
> WEB
> IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
> IMAGEURL "/tmp/"
> END
> # Start of layer definitions
> LAYER
> NAME CAD1
> TYPE LINE
> STATUS ON
> Connectiontype OGR
> CONNECTION "C:\Inetpub\wwwroot\OGR\junk.dgn"
> #CONNECTION "C:\Inetpub\wwwroot\OGR\test_cad.shp"
> CLASS
> COLOR 0 255 0
> END
> END # CAD1
> END # End of MapFile
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
