[mapserver-users] Re: Problem with TestSuite itemquery
Nicole Bömeke
bon at ivv-aachen.de
Fri Apr 19 04:07:34 EDT 2002
Their is a testsuite version for mapserver 3.5 under
http://maps.dnr.state.mn.us/mapserver_demos/tests3.5/.
Untung Rasidin wrote:
> Hi, All
> I have tried TestSuite from
> using mapserv_3.3,mapserv_3.4,and mapserv_3.5, but all failed. Here are
the error messages:
> -using mapserv_3.5:
> Error massage:
> loadLayer(): Unknown identifier. (QUERY):(58)
This error is corrected by the testsuite version for mapserver 3.5. Insead
of
LAYER
CLASS
END
QUERY
TEMPLATE name.html
END
END
for mapserver 3.5 you have to write
LAYER
CLASS
TEMPLATE name.html
END
END
Even using the testsuite version for mapserver 3.5 you might have to correct
something.
I had to add the following to all map files that had no web object defined:
WEB
TEMPLATE name.html
END
Because I have no truetype support I also commented out the following lines:
#FONSET ../fonts/fonts.list
#TYPE TRUETYPE
#FONT arial
Now the Item/value queries and the dynamic queries work correct with my
mapserver.
But I have still a problem with the point query examples and the pan and
zoom example.
For them I get the following error message:
msGetBitmapFont(): GD library error. Invalid bitmap font. Must be one of
tiny, small, medium, large or giant
Has someone an idear how I can correct this?
Nicole
Nicole Bömeke
IVV-Aachen
Germany
