[mapserver-users] OracleSpatial limitations
Rodrigo Cabral
cabral at yadata.net
Fri Apr 19 08:27:58 EDT 2002
Hey there:
Answering your questions:
1. labeling of OracleSpatial shapes not working (Dr. Watson crash on NT)
try doing a LABELITEM "MyOracleSpatialColumnName"
The problem with the labelitem, actually, is the way I'm fecthing data in a
buffer when querying the database for it. This is not an infamous
hard-to-find bug. I'll have it fixed soon. I my last post, I mentioned I
have separated some time in the end of this month to make things work. Do
you have other *item statements in the mapfile? Like classitem? That's
usually when this bug appears, when 2 or more *items are used.
2. multi-column expressions not working (Dr. Watson crash on NT)
try doing a: EXPRESSION ([Column1] > 225 AND [Column2] > 315)
Same reason as above.
3. item query of OracleSpatial shapes not working
see Rodrigo's mail from 11. Jan. 2002 in the mailing list
Wait for the end of the month =)
Regarding some documentation, I would be pleased to help anyone who'd wish
to create a tutorial. I think this tutorial could extend the one that is
presented in the Oracle Spatial reference (section 2.1 - cola markets).
Starts with data creation using SDO SQL and ends up with MapServer display &
query.
Rod.
----- Original Message -----
From: "Bjarni Pjetursson" <Bjarni.Pjetursson at tietoenator.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, April 18, 2002 11:55 AM
Subject: [mapserver-users] OracleSpatial limitations
Hi all,
I've been playing around with MapServer for a couple of weeks now, doing
mapping of SHP-files, OGR-files and spatial data from Oracle. MapServer is
pretty impressive!
I'm using version 3.5 for Windows with OracleSpatial support (got the binary
from http:parvillers.homeip.net/mapserver).
Since (I think) I found a couple of bugs/limitations in the OracleSpatial
support, I was wondering if anyone knows the current status on the following
issues:
Any links to MapServer with OracleSpatial support would also be appreciated.
Regards
Bjarni Thor Pjetursson
