[mapserver-users] OracleSpatial limitations
Yu-Hsin Chen
ychen at yorktel.com
Thu Apr 18 13:32:35 EDT 2002
Bjarni:
It is interesting that I just sent off a question related with your item 3.
I'm running the Mapserver on a Linux system and I don't have any problem with what you described as in 1 and 2. Since you got our favorite Dr. Watson involved, do you want to try to recompile your Mapserver or if you can find another Windows box with less applications and try on it? This may be a good incentive for you to get your hands wet on Linux/Unix system and it probably benefits in the long run.
Yu-Hsin Chen
-----Original Message-----
From: Bjarni Pjetursson [mailto:Bjarni.Pjetursson at tietoenator.com]
Sent: Thursday, April 18, 2002 10:55 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] OracleSpatial limitations
Hi all,
I've been playing around with MapServer for a couple of weeks now, doing
mapping of SHP-files, OGR-files and spatial data from Oracle. MapServer is
pretty impressive!
I'm using version 3.5 for Windows with OracleSpatial support (got the binary
from http:parvillers.homeip.net/mapserver).
Since (I think) I found a couple of bugs/limitations in the OracleSpatial
support, I was wondering if anyone knows the current status on the following
issues:
1. labeling of OracleSpatial shapes not working (Dr. Watson crash on NT)
try doing a LABELITEM "MyOracleSpatialColumnName"
2. multi-column expressions not working (Dr. Watson crash on NT)
try doing a: EXPRESSION ([Column1] > 225 AND [Column2] > 315)
3. item query of OracleSpatial shapes not working
see Rodrigo's mail from 11. Jan. 2002 in the mailing list
Any links to MapServer with OracleSpatial support would also be appreciated.
Regards
Bjarni Thor Pjetursson
