AW: [mapserver-users] Problems displaying tiffs and jpegs
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 22 13:04:07 EDT 2002
Nicole,
I the tiff being covered up by subsequent layers? Objects are layered
from the top of the map file to the bottom, so object placed in the file
first are under objects later in the file.
Try a simple test. copy the mapfile and remove all the other layers
except the one you are trying to include and see if it shows up.
Test two. with the test mapfile, remove the EXTENTS line so mapserver is
forced to comput the extents for the shape file and then see if it is
visible.
-Steve
Nicole Bömeke wrote:
> country.jpg and country.wld are in the same directory as the shapefiles
> <cgi-bin>/../htdocs/demo/data/country.jpg. That seems correct to me,
> because when I rename the .wld files so that mapserver can not find them
> I get an error message. The error disapears when the names of the .wld files
> are correct. Seems mapserver looks for them in the directory I put them.
> Nicole
> -----Ursprüngliche Nachricht-----
> Von: Lowell Filak [mailto:lfilak at medinaco.org]
> Gesendet: Montag, 22. April 2002 16:53
> An: Nicole Bömeke; mapserver-users at lists.gis.umn.edu
> Betreff: Re: AW: [mapserver-users] Problems displaying tiffs and jpegs
> This may seem to be a silly question but is country.jpg & country.wld in
> <cgi-bin>/data/country.jpg or in /temp/country.jpg ?
> Unless I'm missing something, I don't see a problem comparing the wld's &
> the extent.
> Lowell F.
> The following message was sent by =?iso-8859-1?Q?Nicole_B=F6meke?=
> <bon at ivv-aachen.de> on Mon, 22 Apr 2002 10:00:17 +0200.
> > I did not change the top of the demo makefile,
> > that means I used the following settings with no PROJECTION defined:
> > NAME DEMO
> > STATUS ON
> > SIZE 600 600
> > EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
> > UNITS METERS
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > WEB
> > HEADER demo_header.html
> > TEMPLATE demo.html
> > FOOTER demo_footer.html
> > MINSCALE 1000
> > MAXSCALE 1550000
> > IMAGEPATH "set in demo_init.html"
> > IMAGEURL "set in demo_init.html"
> > END
> > Nicole
> > Nicole Bömeke
> > IVV Aachen
> > Germany
> > Von: owner-mapserver-users at lists.gis.umn.edu
> > [mailto:owner-mapserver-users at lists.gis.umn.edu]Im Auftrag von Stephen
> > Woodbridge
> > Gesendet: Freitag, 19. April 2002 14:43
> > An: bon at ivv-aachen.de
> > Cc: mapserver-users at lists.gis.umn.edu
> > Betreff: Re: [mapserver-users] Problems displaying tiffs and jpegs
> > Nicole,
> > The .wld files are in some kind of projection in METERS. What does the
> > top of your mapfile look like? Have you specified a PROJECTION .. END?
> > What are your EXTENTS? What are your UNITS?
> > I think maybe these do not match your images. Which would account for
> > your images not showing up.
> > -Steve
> > > Just for testing, I now tried to display images in .jpg format instead
> of
> > > .tif format.
> > > But I got the same result - nothing shows up. I think I'm doing
> something
> > > really wrong.
> > > I used the jpegs created through mapserver in the /temp/ directory
> (output
> > > IMAGETYPE JPEG).
> > > After converting them to greyscale images with Paint Shop Pro, I had two
> > > jpeg images
> > > country.jpg and lakes.jpg. In the world files for these jpegs, I used
> the
> > > minx and the
> > > maxy extend from the shapefiles.
> > > country.wld:
> > > 0.6
> > > 0.0000000000
> > > 0.0000000000
> > > -0.6
> > > 388107.634400379
> > > 5310243.30613897
> > > lakes.wld:
> > > 0.6
> > > 0.0000000000
> > > 0.0000000000
> > > -0.6
> > > 393234.393701
> > > 5303964.87675
> > > To display the jpegs I modified the .map file from the demo like this:
> > > # Start of layer definitions
> > > LAYER
> > > NAME ctybdpy2
> > > TYPE RASTER
> > > STATUS DEFAULT
> > > END
> > > LAYER
> > > NAME lakespy2
> > > TYPE RASTER
> > > STATUS OFF
> > > CLASS
> > > COLOR 49 117 185
> > > END
> > > END
> > > It would be gread, if you could help me, because by now I'm really
> stuck.
> > > Thanks, Nicole.
> > > Nicole Bömeke
> > > IVV Aachen
> > > Germany
> > > -----Original message-----
> > > >>> Nicole Bömeke <bon at ivv-aachen.de> 04/12/02 01:48 AM >>>
> > > > 1.) I read about an example called landsat (that uses tiffs), but I
> > > > can't find a link to it anywhere.
> > > > Can anybody tell me where I can get it or send a zipped copy of
> > > > it to my mail adress?
> > > > 2.) Are there other examples using tiffs available? I need a tiff and
> > > > a corresponding word file
> > > > that is known to work with mapserver.
> > > > 3.) I have the problem that my tiff does not show up.
> > > > It is an 8 Bit uncompressed tiff with size 600 x 600.
> > > > I used a world file like this:
> > > > 0.6
> > > > 0.0000000000
> > > > 0.0000000000
> > > > -0.6
> > > > 400000.00
> > > > 5255555.00
> > > > To try it, I replaces the background layer of the itasca example
> > > > by this layer definition:
> > > > LAYER
> > > > NAME ctybdpy2
> > > > TYPE RASTER
> > > > STATUS DEFAULT
> > > > DATA test.tif
> > > > END
> > > > Has anybody an idear what I can do?
> > > > Thanks, Nicole.
> > > > Nicole Bömeke
> > > > IVV Aachen
> > > > Germany
