[mapserver-users] Mapscript and proj4 support ?
Daniel Morissette
morissette at dmsolutions.ca
Wed Apr 24 08:27:47 EDT 2002
Stephane,
You seem to be missing OGR support as well (in addition to PROJ) in your
PHP Mapscript... I suspect that you are either pointing to the wrong
copy of php_mapscript.so, of your build environment got screwed up
somehow.
I suggest that you first delete php_mapscript.so from your
extension_dir, and try running your test script again to verify that PHP
will complain about php_mapscript.so not being found... if you don't get
an error then the problem is likely that you have two copies of
php_mapscript.so around... you should fix that problem first.
Then reconfigure mapserver, and 'make clean ; make' ... and then
reinstall php_mapscript.so
Daniel
Stephane MOREL wrote:
> Hi,
> Mapscript is installed on my computer. ( Linux suse 7.2 Mapserver 3.5)
> ./mapserver -v -> Mapserver verion 3.5 OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=GDAL INPUT=SHAPEFILE
> As you can see proj is installed.
> When I put phpinfo(); in a php page I get:
> MapScript Version (Nov 27, 2001)
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> As you can see proj is not installed !!!
> What am I missing ?
> Why proj support is not include in my phpinfo() result ?
> Thanks
> stef
