[mapserver-users] Mapscript and proj4 support ?
Stephane MOREL
stephane.morel at vanoise.com
Thu Apr 25 06:57:47 EDT 2002
Thanks a lot Daniel,
you were right I have two copies of php_mapscript.so.
Now it works perfectly.
Could tell me where I can find documentations or examples on how to use
proj4 ?
Thanks
Daniel Morissette a écrit :
> Stephane,
> You seem to be missing OGR support as well (in addition to PROJ) in your
> PHP Mapscript... I suspect that you are either pointing to the wrong
> copy of php_mapscript.so, of your build environment got screwed up
> somehow.
> I suggest that you first delete php_mapscript.so from your
> extension_dir, and try running your test script again to verify that PHP
> will complain about php_mapscript.so not being found... if you don't get
> an error then the problem is likely that you have two copies of
> php_mapscript.so around... you should fix that problem first.
> Then reconfigure mapserver, and 'make clean ; make' ... and then
> reinstall php_mapscript.so
> Daniel
> Stephane MOREL wrote:
> > Hi,
> > Mapscript is installed on my computer. ( Linux suse 7.2 Mapserver 3.5)
> > ./mapserver -v -> Mapserver verion 3.5 OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> > INPUT=GDAL INPUT=SHAPEFILE
> > As you can see proj is installed.
> > When I put phpinfo(); in a php page I get:
> > MapScript Version (Nov 27, 2001)
> > MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> > INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > As you can see proj is not installed !!!
> > What am I missing ?
> > Why proj support is not include in my phpinfo() result ?
> > Thanks
> > stef
Type: text/x-vcard
Desc: Carte pour Stephane MOREL
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020425/e0c5eb23/stephane.morel.vcf
