[mapserver-users] can't display TIFFs
Dylan Keon
keon at nacse.org
Fri Apr 26 01:07:31 EDT 2002
I can't seem to get TIFFs to display using MapServer...I get either a blank
page or a "server not found" error. I'm using a modified version of the
Europe PHP example (nothing fancy), and I can display shapfiles just fine,
unless the raster layer is included in the mapfile. If I comment out that
raster layer, everything displays fine once again.
I've tried three different TIFFs, with no luck. All TIFFs are in the
correct projection & datum, are 8 bit images, and display fine with the
associated shapefiles in other applications. The TIFFs were created using
the GRIDIMAGE command in ArcInfo, and I renamed the .tfw extension to .wld
(tried it both ways, actually). And it's not a permissions problem. I've
tried both colormap and grayscale images, with no difference. I followed
the "Raster HOWTO" instructions, and the "Converting ArcINFO Grids to
Mapserver TIFFs" instructions in the Wiki, but neither helped. Am I missing
a format from GDAL or something? (see below). I compiled
Mapserver --without-tiff.
Thanks for any help, not sure what to try next.
--Dylan
machine stats
SuSE 7.3 Linux (on 550MHz PIII box)
mapserver 3.5 apache 1.3.22
php 4.0.6 gdal 1.1.7
gd 1.8.4 libtiff 3.5.7
libgeotiff 1.1.4
output from mapserv -v
> ./mapserv -v
MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
output from gdal-config --formats
> ./gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb xpm sdts raw dted mem
jdem envisat elas fit vrt usgsdem gif jpeg png grass
mapfile sample
LAYER
NAME testdrg
TYPE raster
DATA testdrg.tif
STATUS on
END
ArcInfo GRIDIMAGE command
Grid: GRIDIMAGE DRG1232 drg1232.clr testdrg TIFF NONE
(I've also used the COMPRESSION option, no effect on the problem)
output from tiffinfo
> tiffinfo testdrg.tif
testdrg.tif: Warning, unknown field with tag 33550 (0x830e) ignored.
testdrg.tif: Warning, unknown field with tag 33922 (0x8482) ignored.
TIFF Directory at offset 0x8
Subfile Type: (0 = 0x0)
Image Width: 4433 Image Length: 5863
Resolution: 0.124, 0.124 (unitless)
Bits/Sample: 8
Compression Scheme: None
Photometric Interpretation: palette color (RGB from colormap)
Software: "Arc/Info"
Samples/Pixel: 1
Rows/Strip: 2
Planar Configuration: single image plane
Color Map: (present)
