[mapserver-users] can't display TIFFs
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Fri Apr 26 12:48:07 EDT 2002
Check if your GDAL was compiled with TIFF support:
gdal-config --formats
gtiff should be there, if it's not then you have to install libtiffs on
your system or configure gdal to use the internal tiff support:
./configure --with-libtiff=internal --with-geotiff=internal
> I can't seem to get TIFFs to display using MapServer...I get either a blank
> page or a "server not found" error. I'm using a modified version of the
> Europe PHP example (nothing fancy), and I can display shapfiles just fine,
> unless the raster layer is included in the mapfile. If I comment out that
> raster layer, everything displays fine once again.
> I've tried three different TIFFs, with no luck. All TIFFs are in the
> correct projection & datum, are 8 bit images, and display fine with the
> associated shapefiles in other applications. The TIFFs were created using
> the GRIDIMAGE command in ArcInfo, and I renamed the .tfw extension to .wld
> (tried it both ways, actually). And it's not a permissions problem. I've
> tried both colormap and grayscale images, with no difference. I followed
> the "Raster HOWTO" instructions, and the "Converting ArcINFO Grids to
> Mapserver TIFFs" instructions in the Wiki, but neither helped. Am I missing
> a format from GDAL or something? (see below). I compiled
> Mapserver --without-tiff.
> Thanks for any help, not sure what to try next.
> --Dylan
> machine stats
> SuSE 7.3 Linux (on 550MHz PIII box)
> mapserver 3.5 apache 1.3.22
> php 4.0.6 gdal 1.1.7
> gd 1.8.4 libtiff 3.5.7
> libgeotiff 1.1.4
> output from mapserv -v
> > ./mapserv -v
> MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> output from gdal-config --formats
> > ./gdal-config --formats
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb xpm sdts raw dted mem
> jdem envisat elas fit vrt usgsdem gif jpeg png grass
> mapfile sample
> LAYER
> NAME testdrg
> TYPE raster
> DATA testdrg.tif
> STATUS on
> END
> ArcInfo GRIDIMAGE command
> Grid: GRIDIMAGE DRG1232 drg1232.clr testdrg TIFF NONE
> (I've also used the COMPRESSION option, no effect on the problem)
> output from tiffinfo
> > tiffinfo testdrg.tif
> testdrg.tif: Warning, unknown field with tag 33550 (0x830e) ignored.
> testdrg.tif: Warning, unknown field with tag 33922 (0x8482) ignored.
> TIFF Directory at offset 0x8
> Subfile Type: (0 = 0x0)
> Image Width: 4433 Image Length: 5863
> Resolution: 0.124, 0.124 (unitless)
> Bits/Sample: 8
> Compression Scheme: None
> Photometric Interpretation: palette color (RGB from colormap)
> Software: "Arc/Info"
> Samples/Pixel: 1
> Rows/Strip: 2
> Planar Configuration: single image plane
> Color Map: (present)
-Pushkar S. Pradhan
