[mapserver-users] remove points that were added with addfeature
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 30 15:35:45 EDT 2002
They should not be permanently stored, so the next time you should start
with a void layer, unless you are actually saving the points to a shape
file which is not required to display them.
Can you show use how you are adding the points "on the fly"?
This is probably the part that needs to be changed.
-Steve W.
Debbie Pagurek wrote:
> Hi all,
> I have created an application that adds points to a map "on-the-fly" from an oracle database of lat long coords. I used the mapscript "addfeature" to a "dummy layer" that was set up in my map file. Hoever, I need to know how to then clear these added points from the layer, or make the layer void or something like that.
> Any ideas?
> Thanks,
> D. Pagurek
