[mapserver-users] remove points that were added with addfeatu
re
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Apr 30 16:08:17 EDT 2002
well, you can't really clear the features unless you redraw the map. And if
you are redrawing, just simply don't add those features again.
Every object has a destructor method like so "obj->free()";
hth.
> -----Original Message-----
> From: Debbie Pagurek [mailto:pagurekd at em.agr.ca]
> Sent: Tuesday, April 30, 2002 1:45 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] remove points that were added with
> addfeature
> Hi all,
> I have created an application that adds points to a map
> "on-the-fly" from an oracle database of lat long coords. I
> used the mapscript "addfeature" to a "dummy layer" that was
> set up in my map file. Hoever, I need to know how to then
> clear these added points from the layer, or make the layer
> void or something like that.
> Any ideas?
> Thanks,
> D. Pagurek
