[mapserver-users] remove points that were added with addfeature
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Tue Apr 30 16:50:51 EDT 2002
Turning the dummy layer off using:
$oLayer = $map->getLayerByName("dummy layer");
if ($oLayer->status == 1) {
$oLayer->set("status", "0");
should work?
> Hi all,
> I have created an application that adds points to a map "on-the-fly" from an oracle database of lat long coords. I used the mapscript "addfeature" to a "dummy layer" that was set up in my map file. Hoever, I need to know how to then clear these added points from the layer, or make the layer void or something like that.
> Any ideas?
> Thanks,
> D. Pagurek
-Pushkar S. Pradhan
