[mapserver-users] Point inside or outside polygon???
Jan Hartmann
jhart at frw.uva.nl
Thu Aug 1 09:12:04 EDT 2002
Both or none, I would guess. I should vote for both, unless there is a
reason for a point query to exactly return one polygon.
Jan
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of Norman Vine
Sent: Thursday, August 01, 2002 1:33 PM
To: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] Point inside or outside polygon???
Jan Hartmann writes:
>Steve Lime wrote:
>> You can use a point query against the mapinfo data using the normal
>> query or nquery modes. One thing to be aware of it that MapServer's
>> point in polygon routine works fine if the point in question is strictly
>> in/out of the polygon. It's indeterminate if the point is exactly on the
>> edge.
>Why should the result be indeterminate if the point lies on an edge?
Without considering the 'numerical issues' of what it means to be
'exactly on the edge', If you have neigboring polygons which poly
would the point be in if it was on the edge :-)
Cheers
Norman
