[mapserver-users] Image Maps
Manuel Marichal Pérez
marichalperez at yahoo.es
Thu Aug 1 10:01:19 EDT 2002
Hi, all. Image maps are a commonly question treated in Mapserver list.
The solution suggested by MapServer experts is to use Mapscript to read
the shapes and then build up a image map. If your application uses a
java viewer (such us ROSA or other) you can build the map using XML (for
example) and then read it from Java.
Ok. I wrote a PHP/Mapscript function that read the DBF file and extract
the polygons. Each polygon is assigned a label which is extracted from a
column of the DBF itself. With this, I make an XML file including the
map and ROSA read it to manage the "MouseOver" method. This idea works
fine:
http://www.buscamap.com/simpletest/index.html
The problem here is the layer which the image map is build for. If the
layer contains very much polygons, this method take a long time to build
the image map. My question is: it is possible to reduce this time?.
- MapServer is unable to make image maps itself (correct me if not, please)
- If I include a clipping method in the function, I will obtain smaller
XML files, but the time is not reduced because if I want to know which
polygons fall in the view and which fall out of it I still have to read
its coordinates to know it.
- I suppose indexes (shptree) don't help at all because the polygons are
read in order to be treated and then, index are unuseful here.
What can I do if I need image maps in my application and the layer which I
need for contains several polygons?. Any ideas?.
Thanks in advance,
_______________________________________________________________
Yahoo! Messenger
Nueva versión: Webcam, voz, y mucho más ¡Gratis!
Descárgalo ya desde http://messenger.yahoo.es
