[mapserver-users] Styleitem "auto" and MapInfo.
Thomas H. Jensen LE34 MapInfo Center
thj at le34.dk
Mon Aug 5 07:29:42 EDT 2002
Hi.
In simple terms I am trying to build a MapBasic application to let a user specify a MapInfo .Wor file (containing layer information), open the .wor file as a txt file and then building a MapServer file around the specifications in the .Wor file.
As MapInfo stores symbology on the object level (rather than the layer level), I have two options to pursue: I can either use the styleitem "auto" or add a column to my MapInfo tables, store style info in this column and then match it using a classitem approach.
I'm not particularly happy with either approach.
When using styleitem "auto" the following happens to my various MapInfo styles:
Point Objects:
symbol : not tested, but I should be able to match using the symbology files
color : not tested but should be ok.
Line Objects:
Pen Style : Doesn't work. All lines are drawn as full lines
Pen Width : Doesn't work. All lines are drawn width a width of 1
Pen Color : Works just fine.
Region Objects:
Outline Style : Doesn't work. All lines are drawn as full lines
Ourline Width : Doesn't work. All lines are drawn width a width of 1
Outline Color : Works just fine.
Brush ForeColor : Doesn't work. All brush styles are drawn fully and opaque.
Brush BackColor: Doesn't work. Not shown as forecolor fills all
Brush Style : Doesn't work. Drawn as opague.
My main argument against having my application build a mapfile "manually" is that this (as far as I can tell) would require me to add a column to each of my various tables - And I have no idea of wether or not the tabfiles in my .wor files are write enabled.
I would, of course, like to get the MapServer display as close as possible to the original .wor display.
I would greatly appreciate, if you can give me some input as to have I can go on. For example:
I it possible to use a classitem other than a MapInfo column (e.g. some sort of obejctstyle attribute)?
Can I get anything further out of my styleitem "auto" display?
Realizing that the styleitem is experimental, when can I expect the next release of a (hopefully) more complete version?
Am I missing out something completely here (It wouldn't be the first time)?
Thanks for your time.
Med venlig hilsen /Best regards
Thomas Højstrand Jensen
Landinspektør og GIS-udvikler
LE34 MapInfo Center
Energivej 34
2750 Ballerup
Telefon +45 7733 2222
Direkte +45 7733 2217
Fax +45 7733 2299
E-mail: thj at le34.dk
http://www.mapInfo.le34.dk
http://www.le34.dk
http://www.GPSnet.dk - Danmarks Elektroniske Referencenet
