[mapserver-users] MS 3.6.1 - ogr and MapInfo files
Agnieszka Żak
agnieszka_zak at interia.pl
Mon Aug 5 09:14:38 EDT 2002
I get error (Unhandled exception in php.exe (PHP_MAPSCRIPT_36.dll):
0xC000005: Access Violation) when I try to read MapInfo files. But when I
change projection for example to WGS84 in MapInfo program everything is ok.
In .map file I have:
PROJECTION
"init=epsg:4326"
END (for map)
and
PROJECTION
"auto"
END in all MapInfo layers.
OGRINFO:
Layer name: Ciepl
Geometry: Unknown (any)
Feature Count: 3395
Extent: (209405.389158, 869549.161715) - (222399.461459, 879999.984044)
Layer SRS WKT: PROJCS["unnamed",GEOGCS["unnamed",DATUM["MIF
101",SPHEROID["WGS
60",6378165,298.3],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degre
e",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitud
e_of_origin",50],PARAMETER["central_meridian",19],PARAMETER["scale_factor",1
],PARAMETER["false_easting",239910],PARAMETER["false_northing",840880],UNIT[
"Meter",1.0]]
Pole1: String (20.0)
I use:
MapScript Version ($Revision: 1.104.2.1 $ $Date: 2002/06/03 14:19:53 $)
MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks for any help.
Regards,
Agnieszka Żak
Zrodlo rzetelnych informacji... >>> http://link.interia.pl/f1632
