[mapserver-users] syntax for passing a perl variable to setexpression
regina.ctr.niner at faa.gov
Tue Aug 6 14:04:15 EDT 2002
I'm using a perl script to map dynamic
flight tracks against a map of the world.
Would any of you know the correct syntax for using
a perl variable to call setexpression() ?
(I need to build layers based on a variable retrieved from
the database, and have been unsuccessful at using a variable
to set the expression for the applicable class - though
I have gotten a literal to work.)
Any hints would be appreciated.
Thanks!
