[mapserver-users] Problem with PostGIS layer
Tyler Mitchell
TMitchell at lignum.com
Wed Aug 7 10:33:06 EDT 2002
Glad to hear it was simple. As a side note, for Linux (and others?) that
have Postgres start at boot up (i.e. via /etc/rc.d/init.d/postgres script),
I noticed mine did not startup with the tcp/ip connections allowed. I
guess I could have edit the postgresql.conf file, but instead I edit the
startup script. You'll see in the section near the end of the script that
there are some if type statements and then a command to either start, stop
or restart postgres. I simply added the "-i" option at the end of these
commands. However, since it uses the pg_ctl command (and not the
postmaster command directly) I had to flag the "-i" as an option to pass to
postmaster, you do this by preceding it with "-o" for option. Finally, for
example, see the end of the 5th line here as an example.
# Parse command line parameters.
case $1 in
start)
$ECHO_N "Starting PostgreSQL: "$ECHO_C
su - $PGUSER -c "$DAEMON start -D '$PGDATA' -s -l $PGLOG -o -i"
echo "ok"
| | Thomas Haechler |
| | <thaechl at geo.unizh.ch> |
| | Sent by: |
| | owner-mapserver-users at lists.|
| | gis.umn.edu |
| | 08/07/2002 05:49 AM |
| To: mapserver-users <mapserver-users at lists.gis.umn.edu> |
| cc: |
| Fax to: |
| Subject: Re: [mapserver-users] Problem with PostGIS layer |
Many thanks to Dave & Tyler for their help. I am posting this to the
list since I got emails from people with the same problem.
There was actually no problem with the user or permission because for
testing purpose I used the db-admin account. The solution is much more
simple:
I started the postmaster without allowing TCP/IP connetions. This option
is off by default, and since I run the webserver, mapserver and
postgresql on the same machine, I thought it is not necessary.
So for everyone with this problem: make sure to accept TCP/IP
connections. You have 2 possibilities to do this:
1.) use the -i option when starting the postmaster, or
2.) edit the postgresql.conf: tcpip_socket = true
Hope this helps someone else,
Thomy
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
