[mapserver-users] generic way to access shape values from a query
using phpmapscript
Daniel Morissette
morissette at dmsolutions.ca
Wed Aug 7 15:32:12 EDT 2002
Sylvain Pasche wrote:
> I want to display query results using php mapscript. For the moment,
> when I perform a query with msQueryByPoint, I get back a list of shape
> id using the resultcache. Then, when I want to access the values from
> the shape, I directly access the dbf on the disk to read the fields
> values.
> This is ok for shapefile layers, but I would like to do the same with
> other kind of layer, such as opengis, ogr, and others.
> Is there a way to do it with phpmapscript (ie: a generic way to read
> layer item values) and if so, how could this be done ?
In PHP MapScript, the attribute (item) values are returned via a
shapeObj array property called values.
For instance, if your OGR data source contains a field called
"Population", then after a call to $shape = $layer->getShape() you can
access the Population attribute using:
$shape->values["Population"]
Note that you can use print_r( $shape->values ) in PHP to dump the
content of the array and see what the attribute names are.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
