[mapserver-users] OGR - ArcInfo Coverage Help
Lowell Filak
lfilak at medinaco.org
Fri Aug 9 08:35:39 EDT 2002
Alternately you could convert the annotations to two-point lines and label the lines without drawing them (thanks to Steven L. & Daniel M.).
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex10
Lowell F.
The following message was sent by Matthew Archer <ma at t-kartor.se> on Fri, 09 Aug 2002 12:38:25 +0200.
> Hi,
> I am trying to draw ArcInfo annotation via OGR, using MapServer v3.6.1
> (windows binary) on Windows NT.
> I cannot get MapServer to draw the actual annotation text. Is this
> possible, have i got a syntax error somewhere.
> regards
> /Matthew
> Extract from arc DESCRIBE command on cover:
> Description of DOUBLE precision coverage anno15b
> FEATURE CLASSES
> Number of Attribute Spatial
> Feature Class Subclass Features data (bytes) Index?
> ANNOTATIONS SDE 2188 524 Yes
> Extract from arc ITEMS anno15b.tatsde command on cover:
> ITEM NAME WIDTH OUTPUT TYPE
> SDE# 4 5 B
> SDE-ID 4 5 B
> OBJECT_ID 4 10 B
> ANNOTYPE 30 30 C
> NAME 250 250 C
> Using the following syntax with TYPE=Point:
> LAYER
> NAME anno15
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "C:\apache\htdocs\gt2\data\anno15b,0"
> STATUS default
> CLASS
> COLOR 0 0 0
> END
> END
> Mapserver draws points at the start of where each annotation string should be.
> Using the following syntax with TYPE=Annotation:
> LAYER
> NAME anno15
> TYPE ANNOTATION
> CONNECTIONTYPE OGR
> STATUS default
> CLASS
> COLOR 0 0 0
> END
> END
> Mapserver draws nothing for this layer, but gives no error either. The
> rest of the layers still draw.
> Using the following syntax with TYPE=Annotation and with a TEXT fixed label:
> LAYER
> NAME anno15
> TYPE ANNOTATION
> CONNECTIONTYPE OGR
> STATUS default
> CLASS
> COLOR 0 0 0
> TEXT "hello"
> LABEL
> COLOR 0 0 0
> END
> END
> END
> Mapserver draws the default text where each annotation string should have been.
> Using the following syntax with TYPE=Annotation and with a LABELITEM:
> LAYER
> NAME anno15
> TYPE ANNOTATION
> CONNECTIONTYPE OGR
> STATUS default
> LABELITEM "NAME"
> CLASS
> COLOR 0 0 0
> END
> END
> MapServer gives the error:
> msOGRLayerInitItemInfo(): OGR error. Invalid Field name: NAME
> I have tried both NAME,name,Name without success
