[mapserver-users] OGR - ArcInfo Coverage Help
Matthew Archer
ma at t-kartor.se
Fri Aug 9 08:37:45 EDT 2002
Converting to lines works for some texts, however:
How do i get the text to follow the line?
Unfortunately, converting to lines does not work well for 3+ point lines
(ie curved text) and multi-row text where each row is set specifically
(wordposition in ArcInfo).
/Matthew
At 08:35 2002-08-09 -0400, you wrote:
>Alternately you could convert the annotations to two-point lines and label
>the lines without drawing them (thanks to Steven L. & Daniel M.).
>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex10
>Lowell F.
>The following message was sent by Matthew Archer <ma at t-kartor.se> on Fri,
>09 Aug 2002 12:38:25 +0200.
> > Hi,
> > I am trying to draw ArcInfo annotation via OGR, using MapServer v3.6.1
> > (windows binary) on Windows NT.
> > I cannot get MapServer to draw the actual annotation text. Is this
> > possible, have i got a syntax error somewhere.
> > regards
> > /Matthew
> > Extract from arc DESCRIBE command on cover:
> > Description of DOUBLE precision coverage anno15b
> > FEATURE CLASSES
> > Number of Attribute Spatial
> > Feature Class Subclass Features data (bytes) Index?
> > ANNOTATIONS SDE 2188 524 Yes
> > Extract from arc ITEMS anno15b.tatsde command on cover:
> > ITEM NAME WIDTH OUTPUT TYPE
> > SDE# 4 5 B
> > SDE-ID 4 5 B
> > OBJECT_ID 4 10 B
> > ANNOTYPE 30 30 C
> > NAME 250 250 C
> > Using the following syntax with TYPE=Point:
> > LAYER
> > NAME anno15
> > TYPE POINT
> > CONNECTIONTYPE OGR
> > CONNECTION "C:\apache\htdocs\gt2\data\anno15b,0"
> > STATUS default
> > CLASS
> > COLOR 0 0 0
> > END
> > END
> > Mapserver draws points at the start of where each annotation string
> should be.
> > Using the following syntax with TYPE=Annotation:
> > LAYER
> > NAME anno15
> > TYPE ANNOTATION
> > CONNECTIONTYPE OGR
> > STATUS default
> > CLASS
> > COLOR 0 0 0
> > END
> > END
> > Mapserver draws nothing for this layer, but gives no error either. The
> > rest of the layers still draw.
> > Using the following syntax with TYPE=Annotation and with a TEXT fixed
> label:
> > LAYER
> > NAME anno15
> > TYPE ANNOTATION
> > CONNECTIONTYPE OGR
> > STATUS default
> > CLASS
> > COLOR 0 0 0
> > TEXT "hello"
> > LABEL
> > COLOR 0 0 0
> > END
> > END
> > END
> > Mapserver draws the default text where each annotation string should
> have been.
> > Using the following syntax with TYPE=Annotation and with a LABELITEM:
> > LAYER
> > NAME anno15
> > TYPE ANNOTATION
> > CONNECTIONTYPE OGR
> > STATUS default
> > LABELITEM "NAME"
> > CLASS
> > COLOR 0 0 0
> > END
> > END
> > MapServer gives the error:
> > msOGRLayerInitItemInfo(): OGR error. Invalid Field name: NAME
> > I have tried both NAME,name,Name without success
