[mapserver-users] Simple Map File Question
Steve Lime
steve.lime at dnr.state.mn.us
Fri Aug 9 10:31:26 EDT 2002
The mapserver CGI version considers ALL non-default layers to be off.
First thing it does after processing the mapfile and the user input is
to turn all layers off. It then steps through the layer list provided by
the user and turns those on. Bottom line? STATUS ON/OFF makes no
difference to the CGI version. You must explicitly request that
non-default layers be on. Make sense?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Zhang, William" <wzhang at c-cor.net> 08/08/02 07:07PM >>>
I succeeded in compiling and runing MapServer demo on Win2000 with IIS
5.0.
Now I am trying to study the tutorials and get problem. When I run the
tutorial Section 1 -- Example 1 with the map file
NAME S1EX1
EXTENT -97.238976 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "C:\Inetpub\wwwroot\itasca\test\tutorial35"
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "STATE"
CLASS
NAME "Michigan"
COLOR 255 255 128
OUTLINECOLOR 0 0 0
END # end of class object
END # end of layer object
END # end of map file
It works fine. But when I changed the map file to
NAME S1EX1
SIZE 400 300
LAYER # Roads
NAME "roads"
DATA roads_ugl
STATUS ON
TYPE LINE
CLASSITEM "ROAD"
CLASS
NAME "MichiganROAD"
COLOR 255 255 128
This does not work. It only shows a blank box. I downloaded
roads_ugl.shp,
roads_ugl.shx and roads_ugl.dbf from
http://terrasip.gis.umn.edu/projects/tutorial35/download.html
and put them in the SHAPEPATH specified directory. I think it must be
something wrong in my map file. Could somebody kindly give me a hint?
Thanks,
William Zhang
C-Cor.net
E-Mail: wzhang at c-cor.net
Phone: (925) 251-3019
Fax: (925) 467-0600
