[mapserver-users] Simple Map File Question
Zhang, William
wzhang at c-cor.net
Fri Aug 9 17:30:09 EDT 2002
First I would like to thank all your answers. But somehow I still can't make
it work. I changed the status to DEFAULT and the extent to -99 40 -80 52
(states_ugl and roads_ugl covers the same area. So I think this extent
should be good enough.). Here is the new map file.
NAME s1new
EXTENT -99 40 -80 52
SIZE 400 300
SHAPEPATH "C:\Inetpub\wwwroot\itasca\test\tutorial35"
LAYER # Roads
NAME "roads"
DATA roads_ugl
STATUS DEFAULT
TYPE LINE
CLASSITEM "ROAD"
CLASS
NAME "MichiganROAD"
COLOR 255 255 128
END # end of class object
END # end of layer object
END # end of map file
I tried following two strings to retrive map image
<img border="1"
src="/scripts/mapserv.exe?map=C:\Inetpub\wwwroot\itasca\test\s1new.map&mode=
map">
<img border="1"
map&layer=roads">
They all do not work. Is it possible that "mode=map" can't handle too many
lines?
Thanks,
William
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Friday, August 09, 2002 7:31 AM
To: wzhang at c-cor.net; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Simple Map File Question
The mapserver CGI version considers ALL non-default layers to be off.
First thing it does after processing the mapfile and the user input is
to turn all layers off. It then steps through the layer list provided by
the user and turns those on. Bottom line? STATUS ON/OFF makes no
difference to the CGI version. You must explicitly request that
non-default layers be on. Make sense?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Zhang, William" <wzhang at c-cor.net> 08/08/02 07:07PM >>>
I succeeded in compiling and runing MapServer demo on Win2000 with IIS
5.0.
Now I am trying to study the tutorials and get problem. When I run the
tutorial Section 1 -- Example 1 with the map file
NAME S1EX1
EXTENT -97.238976 41.619778 -82.122902 49.38562
SIZE 400 300
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "STATE"
CLASS
NAME "Michigan"
COLOR 255 255 128
OUTLINECOLOR 0 0 0
It works fine. But when I changed the map file to
NAME S1EX1
SIZE 400 300
LAYER # Roads
NAME "roads"
DATA roads_ugl
STATUS ON
TYPE LINE
CLASSITEM "ROAD"
CLASS
NAME "MichiganROAD"
COLOR 255 255 128
This does not work. It only shows a blank box. I downloaded
roads_ugl.shp,
roads_ugl.shx and roads_ugl.dbf from
http://terrasip.gis.umn.edu/projects/tutorial35/download.html
and put them in the SHAPEPATH specified directory. I think it must be
something wrong in my map file. Could somebody kindly give me a hint?
Thanks,
William Zhang
C-Cor.net
E-Mail: wzhang at c-cor.net
Phone: (925) 251-3019
Fax: (925) 467-0600
