[mapserver-users] build 3.6.1 warnings and errors
Puneet Kishor
pkishor at GeoAnalytics.com
Mon Aug 12 10:12:52 EDT 2002
Lowell, Zak,
Thanks for the help. Also, thanks to DM.
I cleaned the crap out of my machine... everything conceivably related to
ms3.5. Started afresh, and Perl/Mapscript compiled.
I wonder if an uninstall script would be worthwhile... a log could be
created indicating what was installed where and what version. The uninstall
script could work with that log, optionally removing older junk.
Needless to say, Perl/Mapscript commands have changed. That, of course, is
another challenge...
thanks to you all for the great work.
pk/
> -----Original Message-----
> From: Lowell Filak [mailto:lfilak at medinaco.org]
> Sent: Monday, August 12, 2002 8:54 AM
> To: Zak James; Puneet Kishor
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] build 3.6.1 warnings and errors
> I can't seem to reproduce the error you're getting. However
> did you make sure to do a 'make clean' in both the
> mapserver-* & mapserver-*/mapscript/perl directory before
> trying to build mapscript?
> Lowell F.
> The following message was sent by Zak James
> <zak-ms at aiya.dhs.org> on Sat, 10 Aug 2002 23:24:28 -0400.
> > Does perl/mapscript build ok with older gcc versions on OS
> X 10.1.5?
> > What does gcc -v return?
> > Zak
> > On Friday, August 9, 2002, at 10:49 PM, Puneet Kishor wrote:
> > > Thanks for the suggestion Daniel.
> > > A few questions --
> > >>> well, it seems to be ranlib-ing, but complains about it
> being "out of
> > >>> date".
> > >>> I am wondering if it has something to do with the fact
> that some
> > >>> stuff got
> > >>> written to
> > >>> cp -f libmap.a /usr/local/lib/
> > >>> cp -f map.h /usr/local/include/mapserver-3.5/
> > >>> during ms make install.
> > >> MapServer's 'make install' target should be avoided. It
> has no real
> > >> use, except confusing your build when you upgrade to a
> new version of
> > >> MapServer.
> > > I am not sure what you mean by "'make install' target should be
> > > avoided." I never gave any target. All I did was 'make
> install' at the
> > > prompt. Are you saying I don't need to 'make install'?
> > >> I suggest deleting /usr/local/lib/libmap.a, and
> > >> /usr/local/include/mapserver-3.5/map.h, and then restart
> your build
> > >> (make clean; make) ... the problem may go away.
> > > Did that, and am now faced with the following...
> > > Mapserv builds fine, but Perl/Mapscript refuses to.
> Croaks out with the
> > > message --
> > > /usr/bin/ld: table of contents for archive:
> /usr/local/lib/libmap.a is
> > > out of date; rerun ranlib(1) (can't load from it)
> > > make: *** [blib/arch/auto/mapscript/mapscript.bundle] Error 1
> > > Any suggestion?
> > > Tia,
> > > pk.
