[mapserver-users] build 3.6.1 warnings and errors
Lowell Filak
lfilak at medinaco.org
Mon Aug 12 09:54:02 EDT 2002
I can't seem to reproduce the error you're getting. However did you make sure to do a 'make clean' in both the mapserver-* & mapserver-*/mapscript/perl directory before trying to build mapscript?
Lowell F.
The following message was sent by Zak James <zak-ms at aiya.dhs.org> on Sat, 10 Aug 2002 23:24:28 -0400.
> Does perl/mapscript build ok with older gcc versions on OS X 10.1.5?
> What does gcc -v return?
> Zak
> On Friday, August 9, 2002, at 10:49 PM, Puneet Kishor wrote:
> > Thanks for the suggestion Daniel.
> > A few questions --
> >>> well, it seems to be ranlib-ing, but complains about it being "out of
> >>> date".
> >>> I am wondering if it has something to do with the fact that some
> >>> stuff got
> >>> written to
> >>> cp -f libmap.a /usr/local/lib/
> >>> cp -f map.h /usr/local/include/mapserver-3.5/
> >>> during ms make install.
> >> MapServer's 'make install' target should be avoided. It has no real
> >> use, except confusing your build when you upgrade to a new version of
> >> MapServer.
> > I am not sure what you mean by "'make install' target should be
> > avoided." I never gave any target. All I did was 'make install' at the
> > prompt. Are you saying I don't need to 'make install'?
> >> I suggest deleting /usr/local/lib/libmap.a, and
> >> /usr/local/include/mapserver-3.5/map.h, and then restart your build
> >> (make clean; make) ... the problem may go away.
> > Did that, and am now faced with the following...
> > Mapserv builds fine, but Perl/Mapscript refuses to. Croaks out with the
> > message --
> > /usr/bin/ld: table of contents for archive: /usr/local/lib/libmap.a is
> > out of date; rerun ranlib(1) (can't load from it)
> > make: *** [blib/arch/auto/mapscript/mapscript.bundle] Error 1
> > Any suggestion?
> > Tia,
> > pk.
