[mapserver-users] build 3.6.1 warnings and errors
Zak James
zak-ms at aiya.dhs.org
Sat Aug 10 23:24:28 EDT 2002
Does perl/mapscript build ok with older gcc versions on OS X 10.1.5?
What does gcc -v return?
Zak
On Friday, August 9, 2002, at 10:49 PM, Puneet Kishor wrote:
> Thanks for the suggestion Daniel.
> A few questions --
>>> well, it seems to be ranlib-ing, but complains about it being "out of
>>> date".
>>> I am wondering if it has something to do with the fact that some
>>> stuff got
>>> written to
>>> cp -f libmap.a /usr/local/lib/
>>> cp -f map.h /usr/local/include/mapserver-3.5/
>>> during ms make install.
>> MapServer's 'make install' target should be avoided. It has no real
>> use, except confusing your build when you upgrade to a new version of
>> MapServer.
> I am not sure what you mean by "'make install' target should be
> avoided." I never gave any target. All I did was 'make install' at the
> prompt. Are you saying I don't need to 'make install'?
>> I suggest deleting /usr/local/lib/libmap.a, and
>> /usr/local/include/mapserver-3.5/map.h, and then restart your build
>> (make clean; make) ... the problem may go away.
> Did that, and am now faced with the following...
> Mapserv builds fine, but Perl/Mapscript refuses to. Croaks out with the
> message --
> /usr/bin/ld: table of contents for archive: /usr/local/lib/libmap.a is
> out of date; rerun ranlib(1) (can't load from it)
> make: *** [blib/arch/auto/mapscript/mapscript.bundle] Error 1
> Any suggestion?
> Tia,
> pk.
