[mapserver-users] build 3.6.1 warnings and errors
Puneet Kishor
pkishor at GeoAnalytics.com
Fri Aug 9 22:49:28 EDT 2002
Thanks for the suggestion Daniel.
A few questions --
On Friday, August 9, 2002, at 05:04 PM, Daniel Morissette wrote:
> Puneet Kishor wrote:
>> well, it seems to be ranlib-ing, but complains about it being "out of
>> date".
>> I am wondering if it has something to do with the fact that some stuff
>> got
>> written to
>> cp -f libmap.a /usr/local/lib/
>> cp -f map.h /usr/local/include/mapserver-3.5/
>> during ms make install.
> MapServer's 'make install' target should be avoided. It has no real
> use, except confusing your build when you upgrade to a new version of
> MapServer.
I am not sure what you mean by "'make install' target should be
avoided." I never gave any target. All I did was 'make install' at the
prompt. Are you saying I don't need to 'make install'?
> I suggest deleting /usr/local/lib/libmap.a, and
> /usr/local/include/mapserver-3.5/map.h, and then restart your build
> (make clean; make) ... the problem may go away.
Did that, and am now faced with the following...
Mapserv builds fine, but Perl/Mapscript refuses to. Croaks out with the
message --
/usr/bin/ld: table of contents for archive: /usr/local/lib/libmap.a is
out of date; rerun ranlib(1) (can't load from it)
make: *** [blib/arch/auto/mapscript/mapscript.bundle] Error 1
Any suggestion?
Tia,
pk.
