[mapserver-users] Mapplet Problem
Martin, Daniel
DMartin at erac.com
Mon Aug 12 15:32:47 EDT 2002
Okay, that makes sense. Definitely not a solution if many JVMs don't
support it.
-Dan
-----Original Message-----
From: Andrew Haigh [mailto:lists.ahaigh at dsl.pipex.com]
Sent: Monday, August 12, 2002 1:50 PM
To: Martin, Daniel
Cc: 'Doug Braeckel'; 'm.spring at gmx.de';
mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Mapplet Problem
You'll find it depends on the version of Java on the users machine. The
latest versions support png.
Andrew
Martin, Daniel wrote:
>I believe Rosa works with PNG. Perhaps it would be a better fit for you?
>-Dan
>From: Doug Braeckel [mailto:BraeckelD at etminc.com]
>Sent: Monday, August 12, 2002 7:30 AM
>To: 'm.spring at gmx.de'; mapserver-users at lists.gis.umn.edu
>Subject: RE: [mapserver-users] Mapplet Problem
>That was the problem. Java didn't like the PNG file. JPG worked great,
but
>the quality, even bumped all the way up, is lacking. I guess I'm going to
>have to go with GIF or just deal with the poor image quality.
>Thanks to everyone who responded. Now I just have to get the "Applet
>mapplet document.form1 has no properties" error figured out.
>Thanks again,
>Doug
>Doug Braeckel
>Senior GIS Programmer
>England, Thims & Miller, Inc.
>PH: (904) 642-8990
>FX: (904) 646-9485
>From: m.spring at gmx.de [mailto:m.spring at gmx.de]
>Sent: Friday, August 09, 2002 3:10 PM
>To: mapserver-users at lists.gis.umn.edu
>Hi,
>your image url points to a png file. At least to my knowlegde java is
>not able to handle png files, but your browser may be!
>Retry with gif or jpg, this (to my knowledge) should work
>Markus
