[mapserver-users] followup - q. combining mapscript and PostGIS
Alex Rice
alex_rice at arc.to
Tue Aug 13 12:07:42 EDT 2002
It appears that the filter on a layer objects only decides the
content, not the extent of the layer. Is that correct? Also, is
it even possible to use Perl DBI from Mapscript? My script dies
when I attempt it:
% ./mapscript.cgi
dyld: perl multiple definitions of symbol _DLAddHead
/Library/Perl/darwin/auto/mapscript/mapscript.bundle definition
of _DLAddHead
/Library/Perl/darwin/auto/DBD/Pg/Pg.bundle definition of _DLAddHead
Thanks for any suggestions,
Alex
Begin forwarded message:
> From: Alex Rice <alex_rice at arc.to>
> Date: Tue Aug 13, 2002 09:32:12 AM US/Mountain
> To: vinko at cprsig.cl
> Subject: Re: [mapserver-users] q. combining mapscript and PostGIS
> On Tuesday, August 13, 2002, at 03:07 AM, Vinko Vrsalovic wrote:
>> I didn't get if you actually do a query in your mapscript code or not.
> So far I am only doing the queries by setting the filter on my
> layer objects using mapscript, not doing a query with DBI.
> This is my first mapscript app and I'm kind of getting a feel for
> the design issues involved.
>> If not, and the queries are done by mapserver libraries and you
>> wish to
>> avoid doing an extra query, my guess is that you can't, because,
>> AFAIU,
>> FILTER is used to determine what is shown, not how... but I may
>> be wrong.
> OK, thanks for confirming. At least two pairs of eyes think so.
>> If you do a query, you could extract the extent in that same query, as
>> in:
>> select name, zipcode, extent(the_geom) as extent from streets where
>> <...> group by name,zipcode;
> Yes, I guess I'll just do this. I may need to use DBI for other
> purposes in this app as well. Not sure.
> Thanks,
> Alex Rice, Software Developer
> Architectural Research Consultants, Inc.
> alex_rice at arc.to
> alrice at swcp.com
