AW: [mapserver-users] nQuery with SDE-Layer
Oliver Wesp
wesp at gdv.com
Thu Aug 15 07:54:56 EDT 2002
O.k. we fixed the problem. Seems like there is problem with getting
integer- or float-values out our SDE-Database. Double-Values are working
fine. This has something to do with motorola-byteorder and passing
values in mapsde.c . We fixed the problem right now and submitted our
changes to Steve Lime. If anybody is facing this problem, feel free to
contact me.
greetings
Oliver
> -----Ursprüngliche Nachricht-----
> Von: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] Im Auftrag
> von Oliver Wesp
> Gesendet: Freitag, 9. August 2002 16:40
> An: mapserver-users at lists.gis.umn.edu
> Betreff: [mapserver-users] nQuery with SDE-Layer
> Dear List,
> I'm facing some strange problems with nquery and SDE-Layers.
> Here is my
> request:
http://myHost/cgi-bin/mapserv?map=/var/apache/htdocs/project/my.map&imge
xt=3360984.898934+5661892.942250+3416530.334032+5703843.458302&layer=myL
ayer&imgxy=477+53&savequery=true&mode=nquery&map_size=592+447
And here is what I get back from Mapserver:
CELL U1 U2 U3
WXB---B 201799 9.15278 4.20013e+12
WXB---A 136218 3.90833 3.5528e+11
WXB---C 201756 7.95556 1.63827e+12
And here - just to show the problem - is what I get back from an
SQL-Select-Statement:
SHAPE CELL U1 U2 U3
5191 WXB---B 3 9,15278 71,28
5146 WXB---A 2 3,90833 53,17
5148 WXB---C 3 7,95556 61,96
For the items U1 and U3 the Mapserver-Results are wrong. Seems to me as
if the values for U1 are case-numbers. I have no clue where the values
for U3 came from. The same problem appears when I use the different
items in class-expressions. For U2 everything works fine, for U1 and U3
the whole thing is busted. All the Ux-Items are numbers.
And here is the setting:
Mapserver 3.6.1
ArcSDE 8.2
Solaris 8
Oracle 8i
any hints?
Oliver
