[mapserver-users] mapscript and image extent
Michael Schulz
mschulz at webgis.de
Fri Aug 16 05:47:50 EDT 2002
is it possible to get mapscript access to the calculated image extent
(in map coordinates) when/after drawing the map image? Because this is
not the same as the actual map extent set in the mapfile, is it?
Thanks, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
