[mapserver-users] mapscript and image extent
Doyon, Jean-Francois
Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Fri Aug 16 10:05:31 EDT 2002
With the CGI version the extent of the map being returned can be accessed
via "[mapext]" ...
In Perl, something like "$map->{extent}->{minx}" (or miny,maxx,maxy) should
give it to you ... Just make sure you call this after any operation has been
performed obviously. This would return the extent of the map for the
current state of the map object.
J.F.
-----Original Message-----
Sent: Friday, August 16, 2002 5:48 AM
To: MapServer Userlist
Subject: [mapserver-users] mapscript and image extent
is it possible to get mapscript access to the calculated image extent
(in map coordinates) when/after drawing the map image? Because this is
not the same as the actual map extent set in the mapfile, is it?
Thanks, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
