[mapserver-users] oracle spatial 9i
Hugues Parvillers
Hugues.Parvillers at AgdF.com
Tue Aug 20 07:55:27 EDT 2002
Tim,
Don't you have the Oracle Error ?
For example look at : http://mapserver.gis.umn.edu/wilma/mapserver-users/0202/msg00333.html
Yu had a defined Oracle error !
H/P
Mackey Timothy a écrit :
> Hi Rodrigo,
> We're using Oracle 9.2.0.1.0, and IAS 1.0.2.2.0.
> We have installed the version of Oracle Spatial that came with Oracle 9i (release 2).
> The 3.6.1 code compiles fine, but requesting a map using mapserver CGI gives a mapserver error: "msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error."
> MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Tim
> -----Original Message-----
> From: Rodrigo Zanato Tripodi [mailto:tripodi at cttmar.univali.br]
> Sent: Tuesday, 20 August 2002 1:54 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] oracle spatial 9i
> Hi,
> I'm working with Rodrigo Cabral at Oracle Spatial support for mapserver.
> Sorry about the lack of support. I was busy with a project at the last weeks.
> I never tried to compile the mapserver with OCI libs from Oracle 9i. But, I
> will test this at this week and try to fix the code if I found any error.
> Can you send me the version of all libraries and the error that you get?
> Are you using Oracle IAS?
> Laboratório de Computação Aplicada - CTTMar/Univali
> http://g10.cttmar.univali.br
> At 16:55 19/08/02 +1000, Mackey Timothy wrote:
> >Hi all,
> >I've got mapserver 3.6.1 CGI to compile and work with Oracle Spatial
> >8.1.7. However, when I compile and run against Oracle 9i (9.2.0.1.0) I get
> >an OracleSpatial error.
> >Does Oracle Spatial support only work with 8.x? If so, is it on the plans
> >to upgrade to 9i?
> >Tim Mackey
> >Web Applications Manager
> >Geoscience Australia
> >timothy.mackey at ga.gov.au
> >http://www.ga.gov.au
