[mapserver-users] [map] tag and $mapObj->processTemplate()
Alex Rice
alex_rice at arc.to
Tue Aug 20 16:22:02 EDT 2002
On Tuesday, August 20, 2002, at 02:18 PM, Steve Lime wrote:
> The CGI version takes any form element and allows you to echo it
> by using the element
> name in brackets. That's how [map] works. There is no section in
> the code specifically
> looking for [map], but since you must always set a map variable
> it always works. Lemme
> look at the processTemplate method for a workaround.
OK I see. I am going to use the tagnames and tagvalues array
parameters in processTemplate. I'll just add [map] in there.
Thanks,
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
