[mapserver-users] Raste Display (More Information)
Tyler Mitchell
TMitchell at lignum.com
Wed Aug 21 17:09:31 EDT 2002
Did you compile the mapserv program yourself? I would recommend
configuring it --without-tiff , since GDAL also has tiff support and you
don't want to confuse mapserv with which to use. That's from my experience
anyway.
If you have gdal installed use "gdalinfo" and tell use what info it gives
you about your image.
Tyler
"gabriel"
<gabriel at ciasc.gov.br> To: <mapserver-users at lists.gis.umn.edu>
Sent by: cc:
owner-mapserver-users at lists. Fax to:
gis.umn.edu Subject: [mapserver-users] Raste Display (More
Information)
08/21/2002 04:14 PM
This is the output from some "TIFF Tools Overview" (tiffdump and tiffinfo)
of my TIF file :
[mapserver at linux geoimagens]$ tiffdump agronomica_trindade.tif
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office"
agronomica_trindade.tif:
Magic: 0x4949 <little-endian> Version: 0x2a
Directory 0: offset 8 (0x8) next 0 (0)
SubFileType (254) LONG (4) 1<0>
ImageWidth (256) LONG (4) 1<924>
ImageLength (257) LONG (4) 1<906>
BitsPerSample (258) SHORT (3) 3<8 8 8>
Compression (259) SHORT (3) 1<1>
Photometric (262) SHORT (3) 1<2>
SamplesPerPixel (277) SHORT (3) 1<3>
RowsPerStrip (278) LONG (4) 1<906>
StripByteCounts (279) LONG (4) 1<2511432>
XResolution (282) RATIONAL (5) 1<100>
YResolution (283) RATIONAL (5) 1<100>
PlanarConfig (284) SHORT (3) 1<1>
ResolutionUnit (296) SHORT (3) 1<2>
Predictor (317) SHORT (3) 1<1>
Software (305) ASCII (2) 15<UMAX MagicScan\0>
DateTime (306) ASCII (2) 20<1999: 5:20 15:49:21\0>
ImageDescription (270) ASCII (2) 48
<\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0 ...>
Model (272) ASCII (2) 48<\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0
37458 (0x9252) BYTE (1) 2<0x1 0xbb>
37459 (0x9253) BYTE (1) 2<0xe0 0x13>
37460 (0x9254) BYTE (1) 2<0xbe 0x6b>
37461 (0x9255) BYTE (1) 2<0x9c 0xc3>
StripOffsets (273) LONG (4) 1<228123>
[mapserver at linux geoimagens]$ tiffinfo agronomica_trindade.tif
agronomica_trindade.tif: Warning, unknown field with tag 317 (0x13d)
ignored.
agronomica_trindade.tif: Warning, invalid TIFF directory; tags are not
sorted in ascending order.
agronomica_trindade.tif: Warning, unknown field with tag 37458 (0x9252)
ignored.
agronomica_trindade.tif: Warning, unknown field with tag 37459 (0x9253)
ignored.
agronomica_trindade.tif: Warning, unknown field with tag 37460 (0x9254)
ignored.
agronomica_trindade.tif: Warning, unknown field with tag 37461 (0x9255)
ignored.
TIFF Directory at offset 0x8
Subfile Type: (0 = 0x0)
Image Width: 924 Image Length: 906
Resolution: 100, 100 pixels/inch
Bits/Sample: 8
Compression Scheme: None
Photometric Interpretation: RGB color
Date & Time: "1999: 5:20 15:49:21"
Software: "UMAX MagicScan"
Image Description: ""
Model: ""
Samples/Pixel: 3
Rows/Strip: 906
Planar Configuration: single image plane
----- Original Message -----
To: mapserver-users at lists.gis.umn.edu
Sent: Wednesday, August 21, 2002 3:50 PM
Subject: Raste Display
I have some TIF images georeferenced at MapInfo software. I would like to
display them with Mapserver.
My MS version is:
mapserver at linux cgi-bin]$ ./mapserv -v
MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
According supported formats list at http://www.remotesensing.org/gdal ,
" If no georeferencing information is available in the TIFF file itself,
GDAL will also check for, and use an ESRI world file with the extention
.tfw, .tiffw or .wld, as well as a MapInfo .tab file (only control points
used, Coordsys ignored)."
Mapserver would have to work with MapInfo file.
But It give-me this message: "msCalculateScale(): General error message.
Invalid image extent."
My .map file is:
# Start of map file
NAME RASTER_
STATUS ON
SIZE 400 300
UNITS METERS
SHAPEPATH "/home/mapserver/geoimagens"
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "zone=22"
# "south"
# "no_defs"
#END
# Start of web interface definition
WEB
TEMPLATE raster.html
IMAGEPATH "/usr/local/apache2/htdocs/ms_demo/tmp/"
IMAGEURL "/ms_demo/tmp/"
END
# Start of layer definitions
LAYER
NAME "agronomica_trindade"
TYPE RASTER
DATA "agronomica_trindade.tif"
STATUS DEFAULT
END #
END # Map File
